windshield washer fluid problem | Ford Explorer - Ford Ranger Forums - Serious Explorations
dj60
Canada
95 XLT
my windshield washer fluid is full, but every time i push the button in to spray nothing happens most of the time. it will spray out washer fluid but usually not on the first try or second or thrid etc. does anyone know what might be causing this?
Join the Elite Explorers $20 Get rid of the ads!
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
. First register on the forum, then join the Elite Explorers to get rid of the ads!
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
timleedude
Honolulu, Hawaii, USA
06 XLT 4.0 6cyl
If you're gonna use wd-40 or brake cleaner fluid, make sure you cover the nozzle with cloth or something so that the fluid doesn't go all over your explorer. And to be safe, wash the area around the nozzle with soap and water so that the paint won't get damaged in any way. I like to play it safe.
-Tim
BrooklynBay
Staff member
Moderator
Brooklyn, NY
gsx220
Philadelphia PA
2002 XLT V8
the button might also be messed up in that combo switch mine takes a few pushes to get it to work.
Ranger379
middle of nowhere, PA
'99 XLT 4X4 4.0 OHV Auto
when i push my button it nothing happens, wiggle it a little tray again a couple times and it works, mine dont make noise like likes trying to spary (like it does when its empty) so wouldnt it be the button?
Tacoma36
Wailuku hawaii
2008 Toyota tacoma
2012 explorer washer fluid not shootin out from front windshield
