wire harness routing for fogs | Ford Explorer Forums
hardball1938
After wiring my new fog lights on my 05 exlorer sport trac I cant find any good way to get the wire thru the firewall with out drilling a new hole any sugestions?
Welcome! I've moved your post to the Sport Trac section. I'm sure there have been modifications by folks there than required running wiring inside.
I added fog lights to mine also but "temporarily" tied them to the parking light circuit until I have time to run them inside.
You did properly fuse them and hopefully used a relay to power them, didn't you?
To Answer your question I have fused them and installed a relay, thanks for checking.
Hey hardball, check right behind your brake pedal, you'll see a rubber grommet in the firewall. A lot of members use this location to get into the truck. I did the same sort of research when installing my fogs. You can poke through the lower rubber, for the hood latch release and you can route a cable through there for your switch.
I agree with ncranchero on the relay aspect too, this way, you can keep all your fog light voltage out under the hood tucked away and just run your relay 12v source in the cab to a switch. There is also a nice storage spot between the fender/body and the battery on the drivers side to zip tie/store your relay and wiring.
When you run the wiring inside the cab through that grommet, use a snake, or coat hanger and poke it out through from the cab into the engine compartment. If you look right around/below the fuse box on the drivers side you should see it poking out (give yourself a good foot or so and you'll see it for sure), then just duct tape or electrical tape your relay wires and pull the snake back through into the cab.
Good luck dude, let us know how you make out!
I picked up the power, fused it and mounted the relay all in a convenient spot just in front of the BJB.
05 Sport Trac Fog Light Install
Good morning thanks for the tip on geting the wires from the engine compartment in to the cab. It worked out great, I also tied the fog light relay to the low beam wire so when I turn on the high beams the fog lights go off as does the OEM. Works well with no problem.
