Routing wires thru firewall? Which access point? | Ford Explorer Forums - Serious Explorations
Tn4x4
hey I'm wanting to install off road lights on my 2010 sport Trac but I don't see any access thru the firewall???
Has anyone routed wires thru firewall for switches in cab, if so, Where?
Would rather avoid drilling into wall....
There Should Be a Rubber Grommet for the Throttle cable , thats were i normally poke mine threw , hope i helped , Good luck
Where's the throttle cable? I'm not really a mechanic....
And what you use to poke thru with?
a flashlight will help , i used a screwdriver to poke threw the rubber
You don't have a tb cable. 06+ Explorers and ST's have drive-by-wire throttle body.
but there still should be a rubber grommet in his firewall ,
But which grommet is better to use? I'm not finding very good access points on the st, it's almost like every grommet I look is so crammed with wires.
Makes me afraid to poke with metal object thinking I'd cut wire coating or something.
well i dont know then
I guess not many people mod the 2006+ models.....
Do we have grommet for drive by wire tb?
Might be in a cluster or harness, either way it has to pass thru the firewall somewhere.
Green I noticed you have a 08 ST
You havent wired anything through the firewall for anything or any mods done to your ST either???
On my 08 ST Limited, I needed to install wires to the grill area. Couldn't find anywhere on the drivers side to get through, so I finally drilled a hole on the passenger side just below the heater wires there. I put a grommet in the hole ran my wires through. It was much easier making a new hole than to try and get wires through on the drivers side.
