Wiring For Power Seat | Ford Explorer Forums
dylanbrady
CANADA
93 XLT
I have 94 explorer without power seats and getting another explorer with power seats. Are all the wire there or will I have to run all the wires?
Thanks
You gotta run them.
I added Limited Leather Seats to my otherwise option-less 92 XL
Not hard.
Ryan
dID YOU RUN THEM TO FUSE BOX UNDER THE HOOD OR WHAT?
tHANKS
You gotta run them.
Not hard.
Ryan
DUDE... I need your help or direction to the thread.. Ive been digging
I have diagrams for a 93 Here
i pulled a set out of a 94 ex an i pulled most of the wire from under the carpet, only 2 wires on there 1 is power the other is ground.
Power seats from a 1993 Explorer Limited
The mount on the Explorer Limited are different than the one on my 1991 ford explorer XL. How will they work
How did you get the power to the seats, and the floor mount look different
If your seats are from a 1st gen they should bolt right to the floor. If they are from a later model the easiest thing to do is remove the rails from your old seats and put them on the new seats. You'll need to drill and tap new holes, but they are marked, so it's not hard to figure out. If you don't have a tap/die set they are only $25-50 at your local hardware store.
The `91 floor is different than the 92-01....it's the ONLY real change in the 91-94 Explorers..
Ryan
My power seats are from a 1993 Explorer Limited Edition and I want to put them in a 1991 Explorer and the floor is different how can I fix the problem?
You need a power seat rack from a 89-92 Ranger, or 91 Explorer.
Ryan
Ryan do you know where I can find a seat rack from 89-90 ranger?
This may come as a suprise....but you can find them in a Ranger.....or even a Bronco II....Bronco's are more likely to have Power Seats.
Check your local wrecking yards, or craigslist...
or check out the parts for sale threads on the following sites:
www.therangerstation.com
www.rangerpowersports.com
www.broncoii.org
Ryan
