429CJ-3X2
- November 6, 2009
- Des Moines, Iowa
- '01,'02, '04 Sport Tracs,
The left turn signal and brake light didn't work on the trailer I bought. The problem seems to be in the truck wiring as that terminal on the truck was dead. Wire doesn't seem to be live on the truck side of the trailer connection just before the terminal. I pulled the taillight and connected a wire there and ran it to the trailer connector. I left the original wire in place too. Thought it was fixed until I hooked to the trailer this morning and immediately blew the fuses to the left taillight and the flasher. Now I have no turn signals on either side of the truck without the trailer.
Replacing the fuses will fix the truck, but how should I run power to that terminal on the trailer hookup? Should I have disconnected the original wire from the taillight to the trailer connector? What other vehicle uses the same factory trailer wiring as a 2002 Sport Trac?
