- April 16, 2002
- British Columbia
- 93 4 dr 4x4 manual XL.
Hey all.
Well the SUV finally left me stranded without it being something I broke.
Just trying to figure it out right now.
What I know:
-Cranks fine, battery is putting out plenty of juice, all wiring seems okay.
-Have spark as verified by pulling a spark plug and watching it fire
-Can hear fuel pump make it's usual sound when I turn the ignition on
-Checked inertia switch
Some symptoms leading up to no-start:
-Every once in a while, would accelerate, most often through a turn at an intersection, and it would momentarily stall out but catch again. Basically would fall on its face for a second..
-It had sat all winter with occasional start ups, but two weeks ago cleaned the MAF and throttle body with carb cleaner when I noticed the previous symptom. it went away, but yesterday did it twice when I went to a friends.
-Today I was pulling out from a corner and it stalled. I pulled to side of road and tried to start. It almost caught, ran for two seconds at a very low idle, then died and will only turn over.
I got a tow home and am thinking it is a fuel issue, the fuel pump has to be coming up on ten years old, but as a lot of people here know, it is a fairly big job to pull it. I am just wondering if anyone has any tips. I searched and there is some info.
-While typing this I realize I should check for pressure at my fuel rail, I`m gunna do that now. Don't have a gauge but I can push that little valve to see...
What I know:
