01ToreadorSport
- October 9, 2008
- Warsaw, IN
- 2001 Sport 4x4
Hi. I recently bought a 2001 Sport 4x4. It has a hitch and was obviously used for towing. The main leaf is separating from the other leafs, but I have seen a lot worse. It has the four pack and not the mono that seems to be standard. The rear was sagging a lot. I made some shackles for it, but they only gave an inch. The front measures 34 1/2" from cement to the wheel lip, with 6" in between the tire and lip. The rear is exactly 1" less in both measurements. These were taken at the center of the wheel and after the shackle install. I do not want to go any longer on the shackles, as they are already 8.5" from hole to hole. I plan on purchasing some 265/75 M/T's soon, and want to do a TT at that time for more lift. I am not sure if the springs are that bad off or has the front height been adjusted already. Can someone please tell me what stock measurements should be. I assume that new leafs are in order, but want to make sure of the front. Thanks.
