Finish it Up
I am pointing to the ground strap at the back of the driver's side valve cover which I removed to install the cover, don't forget to put it back on.
The new thermostat is shown, the vaccum line that used to run to the AC is now rigged to go from the UIM area near the fuel pressure sensor to the air box.
I use dielectric grease on spark plus wires, both ends because I'm from a cold weather climate, wet conditions, etc and this keeps the contact areas really clean. I also use antiseize on things like spark plugs etc that new bolt on the coil bracket, thermostat housing, alternator etc.
I have a pic of the fuel reg area showing that vaccum line that goes to it and T's off to the airbox.
The next one is that hose that runs from the purge cannister to the throttle body and has an electrical plug to connect to under the UIM.
I put in new oil and rad fluid.
The last pic is the
Finish ! Whew! I turned the key on for a few seconds, about 5 or 6 times to pressurize the fuel system and check for leaks. It fired up and runs beautiful. 1st thing my son said when he got home from school,, man that thing runs sweet ! The injectors, rockers, push-rods and new spark plugs were the big updates , everything else was cleaning, essentially.
