paperdesk
- January 25, 2002
- Inchelium, WA
- '05 Explorer
Recently I baught a used 98 xlt. Now the dealer says I have a 97' GEM instead of a 98' GEM and that is causing problems (see below). Does this sound reasonable?
I had problems with the 4x4 high and lo lights blinking instead of the high light staying solid when I switch from auto 4x4 to full time 4x4. I took it to the dealer and they said it was a bad connection. They "repaired" the connection and nothing changed! Now they tell me that it has a 97 GEM instead of a 98'. Does this sound like it would cause this problem? No other GEM controlled electronics seem to be affected. In fact, the 4x4 does work when I put it into full time 4x4 but it doesn't work in auto. I do get a wide varity range in my gas mileage if this might be connected (from 15mph to 18).
Thank you for your advice!
Ted
Ted
