yeah we tried using my Hi-Lift as a come-a-long, that didn't do anything
unfortantly i am sad and ashamed to inform you all that i had to have my buddies :thumbdwn: jeep cherokee pull me out,
atleast he had to come from the backside of the run because he got stuck behind me (where i had already made it through) to jerk strap me out, we got lucky that whole area was extremely unstable the entire ground around you shook and wobble under your feet when you walked, thank god it was below 32 outside or the end result would have been a whole lot worse
by the end of the day i suffered 1 busted up stab. shock
the cherokee ended the day with
1 rear u-joint shatttered
1 rear Pinion yoke broken
1 rear output shaft housing on the t-case blown to hell
1 shattered LF u-joint
1 shattered LF axle shaft
1 LR shock bent into a 90 degree angle (well almost)
i have pics of all his damage if anybody is interest in seeing jeep crap broken
Just
Empty
Every
Pocket
