Nitrous SSC said:So its pretty much bolt in eh?
Heath said:I am SO tempted to try this swap now instead of waiting on an atlas II... Then I could do my D30 swap...
Heath said:Hmmm... Well I'd be okay with not having control trac... Personally I'd prefer to have 2wd, 4hi and 4lo... 2lo would be nice, but not necessary... So knowing that other than an atlas II (my prefrered method) what would you recomend?
Joey p. said:You have the front drive shaft in? What did you use for the shaft? Did I miss something at the end of this thread?
What would be the difference between a manual BW1356 and a BW4406??V8BoatBuilder said:For those who are interested in a manual t-case:
The F150 I pulled the d-shaft from had a manual 4406. Fresh into the yard, it hand't been stripped of its drivetrain, etc.
The case is identical, just no shift motor. The shifter is pretty darn simple, and should bolt to the existing bolt-bosses on the 4r70w's extension housing. All that you gotta do is cut a hole in the floor.![]()
A sport gas tank would still be required, to clear the d-shaft slip yoke.
