SteFin
- March 29, 2011
- nashville tn
- 99 Explorer
Blew a head gasket, and put on new ones timed the chains I have a set of Homemade tools I made (going to post pictures later of the tools). Engine will not fire even squirting starting fluid in Cylinders only showing 60 lbs compression and 35 on # 4. compression doesn't leak down (not going through valves. Wife did drive it 4 miles after temp gauge pegged, it did stop in Field before the Barn (my shop is in the barn) and would not start. Had Water in oil, and set for 7 weeks before I got to it. 2001 Sport sohc engine (engine is 02 and was sweet). I understand these indications are pointing to collapsed rings, after 7 weeks it wouldn't turn over with a 4 foot cheater bar on 1/2" breaker bar used a D-8 bulldozer starter and a explorer start gear and bendix and a 24 volt set up to finally free it and marvel mystery oil down spark plug holes. My cam position tool holds the cam timing/center line notches at 1 5/8" off the head surface for both of the notches with the small radius pointing down towards the engine which allows a 1 1/2" wrench to hold the flats on the cam on the big boss (behind the chain gear)in position. The 1 1/2 wrench works much better than the Ford Hold Down Tool and is a much easier way to position the cam with sprocket nut loose or at only 25 LBs torque. I have another block with good positions however why is it not firing or popping with starting fluid in cylinders and pistons installed (100k) even with 60 LBs I should be getting some noise instead of the wuy wuy wuy wuy of a free spinning engine. Am I being dumber than a road lizard and missing some thing simple and right in front of me. Thanks SteFin (a perplexed shade tree junkyard dog)
