- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
What were the two different rotors in the pictures?
The old one is the stock 11" 1999 rotor. Above that is a 12" cheap eBay 01 Sport part, to get it all together first.
I bought the nice one at the bottom from the Tire Rack about 50k miles later. I like those rotors better than the many I've bought before, I think the Cryro process is worth the money for severe duty use.
I have the rear brakes from an 03/04 Crown Vic that I was going try to install in the rear, when the PO forced an LLV truck on my route. They are not much bigger, but they are vented and would have helped reduce heat for my use then.
I should have the used rotors pictured above, the drilled pair. I don't know if it would be worth it to sell(ship), not knowing what other low cost rotors are out there. I'd give them away for the shipping cost.
