under4egg
- April 25, 2023
- Ukraine
- Explorer Platinum '17
Hi! I have '17 Explorer Platinum. It had front damage so I've got LED foglights with bumper installed from newer car.
The problem chain is following:
suddenly after repair my distronic radar stopped working with B142E DTC code. I tried to initiate calibration but it failed because of active DTC codes. The only one active DTC after clearing was B14E5:55 - not configured. I tried to re-initialize both headlights. It was successful for the right one and failed for the left.
I run BCM self-diagnosis and found the following codes: B14E5:61, B14E5:55, B1147:15, B143C:11, B143B:11, B1305:01.
B1147:15 says my left fog-light doesn't seem to be working but it actually does! I have current on the foglight's input. I tried to disconnect the right one - BCM reports me about that.
I even tried to connect left foglight to the right connector and the BCM says right is fine but the left one is still missing.
So I have current on both pins, I have 100% working foglight but for some reason BCM thinks it's not working or even not installed.
What I'm missing here?
PS. Both of headlights are taken from another car as well as foglights since my was totally destroyed. Right headlight is equipped with original LED ballast control module and the left one has the same color but still taken from another car.
