jwcgc629
- October 30, 2021
- Richmond, VA
- 2017 Explorer Sport
Out of brain-fade, I pressure washed the engine compartment recently, forgetting I never replaced the cap after installing brighter Halogen bulbs. I now have several issues. Right side DRL/LB wont turn off no matter the position of the headlight switch. It stays on for 10 minutes after opening a door or shutting down the engine which would appear the battery saved mode shutting it off, and not the selectable light delay. Left side (where the bulk of the water entered) is DOA for both DRL/LB and signature lighting. Forscan is showing 3 error related to the BCM.....B14E7:11-08 and B14E5:08...both bus signal/message failures with the LED ballasts. The 3rd is B14E0....exterior lamps power supply...fault "circuit short to ground" again, a BCM fault. The BCM has not other fault codes despite the number of functions it controls do I dont think it is the issue. Im wide open for suggestions as to how to use these codes to track down the faulty component or components. Im very savvy with electronics, but this is beyond my pay and knowledge grade. TIA.
