Goonbery
- January 10, 2004
- Saratoga Springs, Utah
- 1997 XLT
Background: Check engine light came on Friday and began blinking, dealership said stop driving and tow the car in, so we did. Report from dealership on Saturday was that it was misfiring on #1, 2 & 4 cylinders. They said all it needed was new spark plugs and wires and the fuel injection system flushed. They wanted $320 for that. They flushed the fuel injection system for $120, I replaced the plugs and wires myself on Sunday.
Car has rough idle and absolutely no power when the gas is depressed. With the pedal to the floor it will get up to 55mph in about 45 seconds. When the rpms reach 3500 there is a popping sound coming from under the hood. The car will not go above 55 mph. I drove it yesterday for about 10 minutes and no light came on, but it did not get any better. Today the check engine light is flashing again.
I want to make sure I connected the spark plug wires back to the correct plugs to eliminate anything I did messing this up. I have been to the local Ford dealer and they don't know what order the wires are supposed to be connected. I have searched online and can find nothing, and I have looking in Chilton's repair manual and can find nothing.
I'm hoping either someone here knows how they are supposed to be hooked up or can at least run out to their truck and look for me.
My Explorer is a '97 XLT with the 4.0L engine, not the SOHC. Help is greatly appreciated, I don't want to have to take it back in and spend $ if it's something that can be easily corrected. The part where the plugs connect on top of the engine looks like this: ( as looking from the front )
3 4
2 6
1 5
Also, any other suggestions on what could be wrong if I did connect the wires correctly would be appreciated. I do have a full powertrain warranty, so if it's something that may be covered, all the better. Thanks so much!
Jeff
BTW- I did also change the serpentine belt this weekend, but after double checking that, it's on correctly.
3 4
2 6
1 5
Jeff
