Convict1997
- January 2, 2003
- Concord, NC
- 1996 2wd XLT 4.0 OHV auto
My plans for a homemade roof rack *DONE*
I missed out on the Coleman roof rack so I'm thinking about making my own. Here's a ms paint drawing of what I'm thinking about doing. The top and bottom rails will be 3/4 EMT. I'd like to make the side supports and bottom slats out of aluminum to save weight, but depending on cost and strength, it might end up being steel. Basically, I'd just bend two pieces of EMT into a squared off "C" for the sides and have one straight piece for the front and back. I don't have access to a welder so the joints will all have to be bolted together. I'd use the connectors for the emt that basically butt the two pieces together and screw down. Make another identical one for the bottom and use pieces of sheet stock to bolt the two together. Then bolt the slats on. Anyone see any problems with this idea? Obviously, the drawing is not done to scale. The width and number of the bottom slats and side supports has not been decided on yet either.
