Fire488
- September 7, 2010
- Monroe Township, New Jersey
- 2007 Explorer Limited V8
I am getting some noise from the front tires from around 35 mph to 70 mph. (humms) I just had my tires replaced and a 4 wheel alignment. The mechanic told me that everything looks and feels tight still. I have about 120k on my 2007 Ford Explorer Limited V8. I tried turning the wheel from left to right at various speeds to make the humming sound get worse, but it did no change all that much. I actually drove my vehicle with this problem from NJ to SC and back and the sound did not increase or get worse. I did try to move the wheel slightly left to right while traveling at 75 mph and although the sound was audibly lower at that speed, I did feel changes and slight vibrations in the steering wheel. I can feel those vibrations at all speeds that I can hear the humm as well.
This all came on after I purchased new tires after putting a few hundred miles on them. The truck does not pull at all and tire pressure is correct.
Not sure what to check , but I will look at the wheel bearings first.
Any ideas?
Any ideas?
