Same APIM as the 2015
Hey Jason,
Can you adapt Sync 3 into 2011-2015 Explorers once its out?
Wow SYNC3 hasn't even been released. No one outside Ford knows.
You posted this on Sync 3 upgrade thread: I am going to point you all at this: http://www.shoforum.com/showthread.php?t=128950
That guy mentioned it is a direct swap, only some configuration is required via CAN
That was a guy who was working on the project for Ford. Needless to say he disappeared.
You mean Sync 3 project?
I thought it was you, honestly...
Not me and I certainly don't work for ford lol
...wait im confused...
I bet SYNC3 runs fine on existing APIM it just wont have the same "pinch and zoom" feature and probably a few others.
Confirmed as incorrect. The Escape is out with SYNC 3. I pulled the OASIS data and totally different APIM part number and the as built data layout way different.
Yes. He worked for the Ford supplier who is supplying Sync3. He no longer works for that supplier.I wonder how that guy with the SHO had it running?.......swapped out APIM?
