Yooper detective
- August 14, 2008
- Negaunee, MI
- 2000 XLT 2wd
Hey, guys:
2000 Ford Explorer 2wd 4 liter, believe the rebuilt engine has about 170k on it. The body has 320k on it and the transmission, replaced 50k ago, was a used unit with 57k on it. I drive about 60k a year in varied weather. The check engine lightbulb itself has been burned out for at least 50k. So no clue if it's still on (a pretty good bet) or if it's blinking out "FOR DEAR GOD JUMP OUT OF THIS TRUCK AND RUN AWAY RIGHT NOW" in Morse Code. I'm thinking the lightbulb may be in panic mode and the bulb itself actually fled the vehicle to save itself.
But...
A couple of recent problems have led to an operating issue. For starters, I replaced the radiator and after this the fluid level kept dropping. I had it overheat once and fluid was actually being expelled from the reservoir bottle under pressure, so assuming there is a head gasket issue somewhere, but it operated all right.
Yesterday I drove 60 miles and noticed a little chugging toward the end of the trip. Then I drove around in that area and every time I started the vehicle it chugged and ran rough, and it ran rough when I was rolling at a steady speed, but it accelerated smoothly and with power.
On the trip home, with cruise on, it ran rough but the severity came and went. Mostly smooth driving. I had to climb a couple of hills and it seemed to have power one time and no power the next time. Whatever the problem is, it's been intermittent at best.
I checked fluids and there's no curdled milk in my oil. Just checked the antifreeze, which was full yesterday, and now it's a quart down, which is about what it does every time I run it for more than 100 miles.
It's outside idling right now and occasionally lets out a popping sound from the exhaust, which is cracked above the muffler.
Sounds like fun.
Anyone have any ideas?
I'm personally hoping bad gas and a weeping leak somewhere that's not related to a head gasket. Going to get the fuel filter changed (150k since it was changed, at least) and crossing my fingers.
Again, any ideas?
Yooper Detective
Yes, I'll drive this until it dies
But...
Sounds like fun.
Again, any ideas?
Yooper Detective
