TestPoint
- August 21, 2009
- Ellijay
- '00 5.0 in an '82 Volvo
You may recognize the never ending saga from my 'handle' but I am putting an '00' Explorer 5.0L into an old Volvo. It is now running . . . but the the #1 cylinder is not firing. All other cylinders work fine. No related DTCodes.
New plug. Observed blue spark on plug laying on engine ground.
The PCM side of the injector reads the 13.6V as I would expect but does not dip on 'injector operate' ground from the PCM. I observed other injectors dropping the voltage down to 4-6v on the PCM ground side. That is really only a sample based on a 500 per second test by the VOM and the PCM timing of the injector operation so it jumped all over the place.
Measured from the injector connector to pin #75 of the C202 PCM harness at 1.7 ohms. Cleaned the male and female connectors there.
Read hi resistance (over 20k ohms) changing grounds on the #1 'tan' injector control wire from the PCM. You have to go to the 20K scale to even read it.
Replaced the #1 injector and still get the same result. I now have a couple spare if anyone needs one.
The really strange confusing thing is that with the injector connector off the engine runs as if one cylinder is dead. With it on it feeds gas into the exhaust with little explosions. Unless this strikes a note with someone disregard for the moment.
Spent a couple hours this morning with a couple PCM rebuilders/tuners in FL. Bottom line is that they wanted $250 for a guaranteed PCM. Then I would have to disable PATS, AGAIN, and one went on to say that I would have to have it reflashed at a FORD dealer.
Plan B: My long time technical coach at the local Ford dealer has now retired. I know where he lives. I am going out there tomorrow morning and see what he has to say.
What say you?
What say you?
