01 5.0 tranny swap | Ford Explorer Forums
01 5.0 tranny swap
shadowless127
Long Island, NY
'01 EB AWD 5.0
Transmission is on it's way out. Slow engagement into forward gears, major slippage.. I'm guessing hardened seals and some cooked clutch packs.
So, I'm going to have a friend of my girl's swap another 4r70w into the truck. Is there anything special we need to know, or is it just a straight up tranny swap?
Also, I think I want to change out the TC too, because I was having some harsh shifts out of OD since I got the truck, so I'm not terribly trusting of the TC either. What's a good TC to get? or should i just search a JY?
If you use a used transmission you use the converter that is with it, do not use your converter on anything if you rebuild your transmission you get a new converter.
Straight up swap, just tight, tight, tight.
