04 Broken front coil spring | Ford Explorer Forums
harry81
petersburg, va
My 04 just broke a front coil spring the second coil from the bottom. Tried to replace it the other day but couldn't seem to get the spring compressor on it cause of the way it broke and also rolled over on to the next coil. Any suggestions will help.
Second that, those front springs are really strong and hard to compress to replace.
An old thread but for anyone else reading this:
I just tried doing front coil springs on my 2003 Mountaineer. Don't even attempt it. Those springs are about the strongest I've ever come across. Even using 4 threaded bar type compressors I couldn't even compress it enough to put the cracked one back on. Only 1/2 of the very bottom coil was cracked so initial plan was just to rotate it and reassemble. Struts themselves, while rusty, were working perfect. The replacement MOOG coils I tried were even tighter plus they had 2 additional wraps over OEM which would also make it more difficult. Maybe a shop could do it but forget about DIY.
Replacing the rear coils a few years back weren't too bad but for the fronts just go with a quick-strut.
Side note: The 02-03 and 04-05 have different spring heights but overall dimensions and fitment are the same. So if replacing both just get whatever quick-strut is cheapest. I was fortunate, being the truck is so old now RA had Motorcraft on clearance for less than aftermarket. And the later version were even cheaper still which is what I ended up getting. Also broke my 1/2 breaker on the bottom bolt. Needed the 3/4 set w/ 24mm socket and a cheater bar to bust them loose. At least they weren't seized in the bushing which I hear is common.
