04 Explorer Manual Lock Alarm Problem | Ford Explorer Forums - Serious Explorations
fatboy SRK
San Diego, CA
2004 Explorer
Hello,
(1) Great site full of wonderful information.
(2) First time poster.
(3) Searched with 'search' function before posting.
I have a 04 Ford Explorer. When I manually lock my car, it arms the alarm. Using a key to open the driver side door sets of the alarm.
This is the gist of it. I get to my destination, and I:
(1) Turn car off.
(2) Unlock Door
(3) Open Door and get out.
(4) Lock door using the "lock door" botton* (while door is open).
(5) Car chirps 3 times (beep beep beep)
(6) Close door.
(7) Car chirps one time. (beep)
*Locking the the car from any entry point sets the alram.
If I go to open the car with my manual key, it sets off the alarm.
This problem happens 95% of the time.
Every once in a while, there will be no locking/opening/ alarm issues, but the car will chirp once very quickly, when I start it.
Any ideas?
I was having funky alarm issues: if the alarm was set and I touched any of the buttons on the keypad on the door the alarm would go off. When I set the alarm the horn would beep twice. I had some other weird electrical issues too. I know that when you set the alarm and get more than one beep of the horn it means something is wrong.
Turns out it was a broken wire in the boot between the driver's door and the body. Once I fixed the broken wire all issues were resolved! This broken/damaged wire is common on the 3rd Gen Ex's. This could also be related to the door ajar switch.
A lot of members have had success by spraying copious amounts of WD-40 into the door by the hinges. This deals with the door ajar switch issue. If you search for this you should find several posts.
Maybe you should try the WD-40 first since that will be the easiest. Then check for broken/damaged wires, since this will cost nothing to look for and minimal $ to repair.
Here is a great thread for removing the door panel and replacing the door ajar switch, thanks to borland for the awesome write-up: http://www.explorerforum.com/forums/showthread.php?t=249253
Here is a great thread for checking for broken/damaged wires, thanks to synyster for this awesome write-up: http://www.explorerforum.com/forums//showthread.php?t=270081
Hope this helps out!
^^^ Thank you. I will check it out and report my findings.
No problem, keep us posted. :D
