04 Explorer V6 PATS and PCM connections
steve miller
Location
California
Barstow
2004 Explorer XLT
Here is the story:
Went to start my explorer and the battery was dead. Put the charger on and it slowly cranked, let it charge some more with the same results (slow cranking and not starting then battery died). Let it charge for about 10 minutes (probably left door open and key on during this 10 minutes) and no crank. Dash lights up, gauges working, radio, etc... When trying to start the voltage gauges doesn't move (i.e. no load on the battery). Noticed when the key is in the ON position, the PATS LED is solid ON. Jumped pins 30 and 87 of the starter relay and it cranks. I'm guessing that the PCM is not grounding pin 85 of the starter relay.
Also when I go through the testing using the odometer display (hold down the odometer reset and turn key on) there is an "ign ihb" on the display?
satephenmiller19
Barstow, CA
2004 ford explorer
I'm not sure what happen to me user name, I post the above question.
Anyhow, does someone have the pin out of the PCM and the PATS module for an 04 Explorer 4.0 automatic. Thanks in advance.
steve miller
satephenmiller19
Barstow, CA
2004 ford explorer
At the 4 pin connect at the key, what signals TX,RCV levels should I see? 13 vdc on pin 1, ground pin 2, TX 12.6 vdc pin 3, RCV 13vdc on pin 4. Is this right?
T 04 Ford Explorer battery went dead now won't start pats system transponder key Stock 2002 - 2005 Explorers 5
J Ford Explorer 2004 pats module problems Stock 2002 - 2005 Explorers 18
D 2002 Ford Explorer XLT with a PATS system failure. Stock 2002 - 2005 Explorers 12
shadowless127 PATS in 04 Aviator same as Explorer/Mountaineer?? Stock 2002 - 2005 Explorers 0
M Location of RAP, GEM, and PATS modules on 02-05 Explorer Stock 2002 - 2005 Explorers 0
1 Loud popping sound and now no reverse! 2004 4.0 Explorer Stock 2002 - 2005 Explorers 8
S Please Help, 2002 standard 4x4 explorer wont go into gear when started Stock 2002 - 2005 Explorers 10
C 03 Explorer 4.0L - Engine noise from intake manifold. Slapping? Ticking? Stock 2002 - 2005 Explorers 3
C SOLVED: 03 Ford Explorer 4.0L - Power windows will not roll up. Stock 2002 - 2005 Explorers 4
KA3NXN 2002 4.6 Explorer has low power and bucks between 40-50mph Stock 2002 - 2005 Explorers 2
F Need Advice about Getting Replacement Tires for 2003 Explorer XLT Stock 2002 - 2005 Explorers 3
G 2004 Explorer XLT with ABS Stock 2002 - 2005 Explorers 1
K 05 Explorer AC not blowing cold: Low side high, high side normal Stock 2002 - 2005 Explorers 1
1 04 Explorer - Cleaned battery cables now stuck in safe mode and codes p2104 p2112 Stock 2002 - 2005 Explorers 9
Z 2002 Ford Explorer ABS light comes on and off pulsating brakes Stock 2002 - 2005 Explorers 0
M 2004 explorer timing chain rebuild Stock 2002 - 2005 Explorers 1
A Loose steering on 04 Ford Explorer XLT 4.6 V8 Stock 2002 - 2005 Explorers 3
S 2002 Explorer Coolant question Stock 2002 - 2005 Explorers 1
B 2005 Explorer Eddie Bauer 4.6L v8 Repeating DTC Error Code P0463 Stock 2002 - 2005 Explorers 0
C 04 explorer brown wire mod Stock 2002 - 2005 Explorers 2
L Rims from 95 Explorer 4wd EB onto 2002 Explorer 4wd EB Stock 2002 - 2005 Explorers 7
4 2005 explorer over heats when ac is turned on all new parts Stock 2002 - 2005 Explorers 11
A 2005 Explorer Transmission problem...imagine that.... Stock 2002 - 2005 Explorers 0
R 05 Explorer. Vibration when turning. Stock 2002 - 2005 Explorers 9
M 03 Explorer 4.6 Super high Idle nothing works so far Stock 2002 - 2005 Explorers 28
S 2002 Explorer Oil Pan replacement Stock 2002 - 2005 Explorers 5
J Need a little help fight in the condensation drain on a 2002 Ford Explorer XLT Stock 2002 - 2005 Explorers 0
J 03 Explorer stuck on heat Stock 2002 - 2005 Explorers 2
N 2002 does explorer xlt transmission help Stock 2002 - 2005 Explorers 0
M exhaust for an 04 explorer?? Stock 2002 - 2005 Explorers 1
S Unknown connector behind the manifold 2002 XLT V8 4.6L Explorer Stock 2002 - 2005 Explorers 4
Y Rear A/C Issue, 2005 Explorer Limited Stock 2002 - 2005 Explorers 2
D 04 Explorer EB reading lamp issue Stock 2002 - 2005 Explorers 1
K Explorer 2004 v8 4.6L, limited, transmission flush Stock 2002 - 2005 Explorers 4
M 2002 Explorer Sport 4WD 2 door Stock 2002 - 2005 Explorers 0
E 5r55s 2003 explorer year interchange Stock 2002 - 2005 Explorers 1
S 2003 Ford explorer xlt quarter window glass Stock 2002 - 2005 Explorers 0
E 03’ 4.0 into an 04’ 4.0 Explorer Stock 2002 - 2005 Explorers 1
S 2003 ford explorer charing issue fusable link replacement? Stock 2002 - 2005 Explorers 1
B 2002 Explorer Rear Camber Issue Stock 2002 - 2005 Explorers 12
V 2005 Explorer pdf manual? Stock 2002 - 2005 Explorers 2
W 04 explorer Stock 2002 - 2005 Explorers 4
R 2002 Explorer 4x4 4.0 , turn off OD for flashing OD light help? Stock 2002 - 2005 Explorers 4
G OEM electric fan on 2003 explorer sport Stock 2002 - 2005 Explorers 1
T 03 Eddie Explorer electric seats Stock 2002 - 2005 Explorers 1
M 2005 ford explorer remote Stock 2002 - 2005 Explorers 3
T 04 explorer Stock 2002 - 2005 Explorers 8
Y Custom door chime for 2005 Explorer Stock 2002 - 2005 Explorers 4
J 2004 Ford Explorer Issue Stock 2002 - 2005 Explorers 2
M Cold start 02 explorer Stock 2002 - 2005 Explorers 0
Similar threads
