Here is the tsb
Printable View (7 KB)
TSB
04-26-20 THROTTLE PEDAL RESPONSE ON TIP-IN
Publication Date: December 23, 2004
FORD: 2004-2005 Explorer
MERCURY: 2004-2005 Mountaineer
This article supersedes TSB 04-22-5 to update applications.
ISSUE:
Some 2004-2005 Explorer 4dr and Mountaineer vehicles built before 10/4/2004 with a 4.0L engine, or before 12/14/2004 with a 4.6L engine, may exhibit issues related to the throttle pedal response on tip-ins from a stop and on deceleration tip-ins.
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration level using WDS release B34.9, or B35.1 and higher. Calibration files may also be obtained at
www.motorcraft.com.
NOTE: THIS NEW CALIBRATION IS NOT INCLUDED IN THE B35 CD.
NOTE: THROTTLE PEDAL RESPONSE WITH ELECTRONIC THROTTLE CONTROL (ETC) DIFFERS FROM RESPONSE WITH A THROTTLE CABLE. REPROGRAMMING THE PCM WILL IMPROVE, BUT MAY NOT ELIMINATE, THIS CONDITION.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
042620A 2004-2005 Explorer/Mountaineer: Check For Diagnostic Trouble Codes And Reprogram Powertrain Control Module 0.4 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
RECAL 04
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2004 Ford Motor Company
