How to: - Convert V8 AWD to BW 4406 Manual Shift- A how to thread | Page 33 | Ford Explorer Forums
How to: Convert V8 AWD to BW 4406 Manual Shift- A how to thread
Prefix for threads which are instructional.
Manual shift does not have a clutch nor does it need the brown wire hooked up to give you 2wd, 4hi and 4 low
It sounds like you have a linkage issue or a defective transfer case
The torque on demand 4406 is an electronic shift t case but has two extra speed sensors, so it is easy to spot
For those people wanting to use the bw 4406e electronic shift version without messing with gem modules we simply use a 2002 ranger 4wd control module. These are also found in other 02+ fords
It’s called the Motorola box and it can be wired to the stock explorer 4wd dash switch and v6 t case shift motor
I'll send a picture of mine. It has a manual shifter on the side and a brown wire coming from the back of it. I don't have my linkage hitched up yet but it definitely is made to be hitched up. My 4x4 high has a clutch in it so what it seems I have is a tod transfer case shifted to 4x4 low manually.
I'm a complete idiot. It has 4 positions but I was to dumb to find the 4x4high position. Sorry to bother yall.i don't know what the brown wire is for on it but I don't care. Now just to get me a front drive shaft that works.
Any 4.6 4wd front driveshaft should work
wasnt the rear DS from the 5.4 expe, and front from the 4.6 f150? or am i mistaken. which model did your front DS come from?
Update. I got a front drive shaft from a 5.4 and it works.
OK update. I just got a front drive shaft from a 5.4 f150 and it will work. Thanks everyone for the help
this should have many pics, not sure if all of them though, but should get you close!
As long as this thread is alive and kicking... Which rear DS is preferred? The regular driveshaft of the Double Cardon(sp?).
imo double cardan, but for near stock height application, it doesnt really matter imo. i would use double cardan in high angle applications, but other than that, not sure how much a reason there is? but perhaps soemone like 410 knows otherwise :D
So the junk yard I've been going to called back and said they don't have the shift linkage. Is this the correct shift linkage Amazon product ASIN B0083H5BUGI know it's only the main part and I would need the bar going to the transfer case and the stick going into the explorer but I can't find either of thoses. Does anyone happen to have a place online I can get everything I need?
The 4406 is a slip yoke rear shaft these use a single u joint at the slip yoke and a single at the rear axle, not sure I have ever seen a slip yoke shaft with double cardan joint
That part from
Dorman looks correct but I do not see a description of fords it fits
I'll try to get a picture taken this week. I'm sure I've had it installed before. I just removed it so I could put in a regular driveshaft while I had new U-Joints put in the double cardan. Then I got busy and never got around to getting the double cardan done.
Don’t forget to change the centering ball in the double cardan joint as well, they are super fun
LoL I hate doing U-Joints. So I'm having new ones put in and the entire thing balanced at a driveline shop.
Use spicer lifetime joints non greasable
Transfer Case Indicator Lights Hookup
Using the Ford CD and a pigtail, I wired up the dash lights for my transfer case. It was easy.
Besides the case, obviously, you need:
  • approx 10 feet of small gauge wire
  • wire connectors
  • relay (optional)
  • wiring diagram of your vehicle
This is an easy job to do and in my opinion worth the effort.
1. Remove the radio bezel, there are two screws under the radio to remove it, they are 7mm. Unhook all of the connectors that are hooked to the bezel.
2. Remove the radio if necessary. I have an aftermarket radio and it came out with the bezel.
3. On the left side of the hole in the dash, the GEM is mounted vertically.
4. Using your wiring diagram, locate the two wires that go to the dash indicators. I would think many years would be similar, but Ford likes to change things up, so do your research. My wires were grey and light blue w/ black stripe.
5. Now that you have the wires located run the wires from the dash to the bottom side of the body. I ran my wires under the carpet to a plug in the body about the size of a quarter that came out just on the outside of the frame on the drivers side.
6. Wire the wires to the two coming from the pigtail. It doesn't matter at this point which wire is which, so just hook them up.
7. Find your shift indicator switch on the transfer case. It is near the shift fork and takes a 22mm hand wrench to remove.
8. Route the wire away from the driveshaft and plug it into the switch. I ran mine from the plug over the frame, over the shift linkage bar, behind the vent hose to ensure id doesn't get near the driveshaft.
9. Go back to the cab. The two wires that you found earlier you need to strip some insulation away from. I just took a wire stripper and cut and pushed the insulation.
10. At this point, don't connect the wires permanantly. Pull your case into 4 hi. Taking one wire from the case at a time touch it to the wire that runs to the dash. Find the wire that lights up the 4 high light.
At this point, you need to decide if it will bother you to have both the high and low light on when the case in in low. The switch works by putting a ground signal when the case is in 4 high, when you pull it into 4 low, the 4 high light and the 4 low light will illuminate if you just hook up the wires. It works well enough I guess, but I wanted it to be correct. Using a standard relay, you can do some simple wiring to correct this.
If It doesn't bother you, hook the wires up and you are done.
EDIT: This sounds confusing, but I don't really know how to make it clearer. (I'm open to suggestions) Once you get in there, it should make more sense. :confused:
11. To wire the relay, find a 12v positive source. The wire for the cigar lighter comes from the GEM and will work for this. Wire the relay as follows-
12v + to the 85 post
Connect the wire from the transfer case that comes on when in 4 low to the 86 post
Connect the wire from the transfer case that comes on when in 4 high to the 30 post
Connect a wire from the 87a post to the wire that goes to the 4 high light
12. Connect the wire from the case that comes on when in 4 low to the wire that goes to the 4 low dash light.
The way this works is, the ground from the 4 low signal trips the relay, cutting the signal to the 4 high light. The 4 high light now only works when in 4 high.
Thats it, put the radio and bezel back and your done!
Where did you get the pigtail, you used for the shift indicator switch/light?
I have made these in the past
The switch in the t case basically has two male prongs
I have plenty of female pins that fit right over the prongs
Then you can wrap it in silicon and let it setup
Blamo pigtail
Otherwise you can buy the connector online
Standard motor products s743 is the pigtail
Standard Motor Products S743 Pigtail/Socket https://a.co/d/fMPFggQ
Blamo pigtail
Ok thank you.
