Thanks, I don't think that is my issue. I drove for a week after changing the bulb. As I said in my last post, after fooling with the fuse box panel and not touching anything that should affect the turn signals, they mysteriously started working. That lasted for about 10 cycles and now back to square one. Going to get a wiring diagram and try to trace problem. Instead of working from the bulb back I am going to start at the fuse panel and work forward as it seems something there has a bad connection. Not looking forward to sending to dealer for hours of diagnostics. Thanks for the help and keep the tips and ideas coming!
The 2007 Explorer SJB appears to be located on driver's side above the parking brake pedal and has at least 3 connectors:
1. C2280A that includes pin 27 with VT-OG wire for the right rear stop/turn bulb; the wiring loom appears to run down to the floor and then to the back of the vehicle under the "carpet".
2. C2280E that includes pin 27 with YE-VT wire for the right front turn bulb; the wiring loom appears to run upward and forward to the engine compartment.
3. C2280D for multi function switch, etc.
For the front right turn signal bulb there does not appear to be a connection after the SJB untill the bulb holder connector block, pin 3. So the same wire colour Yellow/Violet (YE-VT) is used throughout.
For the right rear top/turn bulb there is a junction block inside the vehicle just ahead of the right rear lights connecting to pin 2, then on to the bulb holder at pin 3. The same colur wire Violet/Orange (VT-OG) is used throughout.
Good luck.
Edit: I thought the Explorer and Mountaineer were the same, but they are not. For the Mountaineer the right rear turn signal uses pin 1 at the bulb, wire colours are the same as the Explorer.
For the front right signal lamp there is a repeater. The repeater wire is yellow/Violet and connects the SJB at pin 27 to the repeater, and there is a connector in the right side of the engine compartment (about middle) for the Brown wire from the main signal light to connect.
Sorry for the mistakes.
