1350t-case swap into 95 explorer | Ford Explorer Forums
Travisjim
Morris Ok
1995 xlt
will a 1350 manual shift t-case bolt up to my auto transmission ie bolt pattern splines ect not worried about linkage or driveshafts
Yes it will bolt to your transmission if you're not worried about the drive shafts
thanks i was pretty sure it would. i found a guy with all kinds of ford explorer bronco II parts and he is going to round up all the parts i need to convert i didnt want to waste his time
But I think you'll need to have a custom drive shaft made due to the output of that transfer case I don't think the BII shaft will be long enough.
ya i figured that i am getting the drive shaft with the t-case so just have to retube it
picked up the parts this weekend did some measuring looks like its going to be a bolt in swap even the bronco II front drive shaft is going to work now all i have to do is get to work
im running a bronco II 1350M in my 04 sport trac. Had to get the bronco's stock shaft cut down about 1.5 to 2 inches to work in my setup
That's good to hear I didn't think the shaft would be the right length.
it might not be i just did a quick measure but shortning a shaft is easy enough.
well got it in went good gonna have to shorten front shaft 2 inches. took it for a test drive and in 4 low transmission doesnt want to shift out of 1st in D but will in 2nd but but who needs to go fast in 4 low i might get creative and mount some spring lever switches to t case lever so i dont have to manual switch the cad. hope to have it all done middle of next week can some one tell me how to put pics on here
everything is done wired switch to cad took out to pasture for a test run and first run through mud hole hydrolocked motor pulled plugs got runnin went throught hole all different ways everything worked great
any advice on moving air intake ?
Thanks for all the help guys great advice
Sounds good did you take a picture of your driveshaft of what it looks like modified?
ya i have a pick but it wont let me upload it . i just used stock bronco II shaft shortened 2 inches
