full foot notch
- August 9, 2004
- orlando
- 92 2dr 4x4
Well yall, the front axle is in, but now I am having to address rear driveline issues, since my truck is a 2dr explorer it has a short driveline, and heres the thing, the rear has a severe driveline angle, the driveshaft is at 25 degrees and the pumpkin is at 30-35(not sure), and the perches have been previous cut and welded on the 14 bolt axleand right now its at the shop waiting on what I am going to do, right now I am running a 39.5 bogger in the rear, and I guess due to the driveline angle, the way it is set up, it is going to burn the pinion bearing up since it is over 5 degrees( I guess since it is an oil slinger setup and 5 degrees is the max before damage can occur) the rear is a 6 inch lift spring with 5 inch block to match the 12 inch chevy front springs, so you know I have some height in the truck, my thing is, is there any axle out there that is 1ton and 8 on 6.5 that can hold up to that kinda of angle or am I going to have to change the whole driveline setup to bring it back down, as I do not think there is a high angle driveshaft that can support those kind of angles at both end. Another question is that would it just be worth it to trade the high pinion ford dana 60 front for a set of F&R Rockwell axles and just build it from there since it is a top loader and there would be no problem as far as pinion lubrication and it would also decrease driveshaft angle? Its one of those, I know those dana 60s go for 1300-1500 depending on condition, and I just had mine rebuilt, so I know its worth the $$, and since my truck is at chucks trucks, a set of pullouts is 800 front 500 rear so that’s 1300 total, figure I don’t shorten the long side in the front, ive already paid the $$ to do crossover steering, and pricing it out thru chucks site is pretty much the same for the D60 as the Rockwell in terms of steering arm and draglink, the wheels and tires I could most likely get from USA6x6, and then the wheel brakes is my main concern, I know that the prices have come down some and then I noticed some 1 ton DIY kit that USA6x6 has for $150 per axle, im guessing I could adapt that to work
Its just that this truck has been sitting since march when the axle broke, and I really want to get this truck done and running for right now, and for me to work with what I have, im going to have to invest some $$ to bring it down and smaller tires, or I can invest a lot more and go Rockwell, or at least bargain my way to getting rockwells, I mean im $4k in the hole cause of this stage of stuff right now, im just seriously tired of my truck sitting and I want to drive it again, I just don’t know what to do and at wits end if ya know what I mean
