15x10 classic 2's...31x11.50's will they fit with no lift? | Ford Explorer Forums
benner31
Sonora, California
'93 XLT
anyone out there have any info for me?...i have a 93 xlt...there is no lift...can i squeeze 31.10.50's on a 15x10 inch wheel under the x?....will a 2 in/ body lift help out at all? any info will help?
you're gonna need to search.....
you need the bl (you will rub)
nope.. simple as that
2in body lift. yes
i would be hesitent with 10in wide rims though
im running a 3in body with 32's on 15x8in wheels
i get rubbing only on the driverside for some reason? i've cut half the freggin plastic out and it still rubs, im about to cut the rest out haha
31x10.5s are gonna look a little silly on 10" wide rims anyway IMHO. Slap them on some 15x8s and they will look better, and probably fit with no lift.
if i had the 2 inch bl, do u think im still gonna have stearing problems?..ive got mixed responses from people..the offroad shops around here suck. and theyve all told me different crap about 10 times..what about a 31x11.50?
If you get a 15X10 you'll need a lower back spacing like 3.25", or even 3". They will stick out past the fenders alot. 15X8 with 3.75" backspacing will fit alot better. I just put these on my X with 31X10.5X15's I only rub a little turning lock to lock on the fender lining. I'm getting a 2" suspension lift to correct, but I could live with it if I had to.
my x is a 4wd...the backspacing in 3.75....i know they will stick out alot!....am i gonna have to trim the **** outta the fenders?....thanks for evryone on all the help!
where do u get the 2 in. suspension lift and whats the cost?...think if i had a 2 in suspenison & also 2 in. bl i would be fine?
