DoraNotSoExplorer
- January 21, 2023
- LITTLE ROCK
- 2003 Explorer XLT 4wd 4.o
So 6 months ago while driving my 2003 EXPLORER XLT 4WD 4.OL (5R55S) started having what seems to be trans issues followed by OD light flashing (mind u no problems where speedometer, cruise control,no slipping,ability to down shift as well as ability to go into reverse, no ck engine light accompanying codes whatsoever)...The best way I can describe it is this, it's like someone hit my gear shift & knocked it into neutral while driving. Over the last 6 months it has gradually gotten worse as it went from only doing this in upper gears to now I can't make it to the speed bump 1 house up without having to stop and trying to work it back into gear (which used to work but now almost zero luck) it originally threw 1700 & 0720 codes & just a week ago threw same codes...I'm gonna list below everything that HAS been done/checked in pursuit of a diagnosis....
1) Output Shaft Sensor replaced (part from scrap yard)
2) Fluid drained & replaced (fluid was very dark & low with no metal shavings)
3)Battery area/connectors were thoroughly cleaned...
4)Ground was checked by master electrician & cleared as possible concern 5) 4wd module was unhooked-problem still remained 6) Shift selector position was checked-still not sure if this is correctly in position...any ideas on what to do next??? My next move will be putting it on trailer & taking it to local shop to be put on a snap on computer to diagnosis it, however that is like trying to steal candy from a baby lol
TIA yall
TIA yall
