1989 Towncar transmission leaking into engine? | Ford Explorer Forums
YBCold
Las Vegas NV
91 ×∟┬
right so im thinkin my aunts transmission is leaking ATF fluid into the engine. i notice the oil level is unually high while the trans oil is low ( when engine is cold) then it slips doesnt engage, bad bushing blah blah blah. anyways i looked into it and it has a AOD type transmission but what would i fix on the transmission to stop the leak? i know explorers have the vacum modulator when the diaphram breaks but i dont know if AODs have the same. can anyone enlighten me?
ill check the radiator too. i noticed it also seems to loose coolant. so there is a possibility of a leaky head gasket or warped heads :(
