L.A.X
- July 18, 2013
- Los Angeles, Ca
- 1991 Ford Explorer EB
My explorer cranks and cranks but doesnt start. If for some miracle it does start, it runs good but after idling for awhile completely shuts down like if someone just flipped a switch. The problem started after using seafoam. It might just be a coincidence.
Heres the 411,
When I get in my truck and turn the key to start, if the CHECK ENGINE light illuminates, then truck starts. If CHECK ENGINE light doesnt illuminate, then truck does not start. When truck cranks and cranks, there is no spark. Starting system is all new. Ignition system has new plugs, wires, Crankshaft position sensor and coil pack.
The fuel system consists of 91 octane, new working fuel pump, filter, fuel pressure at the rails.
Not getting power to the injectors. When truck is cranking and not starting, no power to the injectors.
When the truck does run, I have spark, power to the injectors etc. What component could be malfunctioning?
Heres the 411,
