1991 explorer, slave cylinder issues | Ford Explorer - Ford Ranger Forums - Serious Explorations
yluahale
Waialua, Hawaii
1991 explorer
I am attempting to find out if I can bypass to Quick disconnect coupling between the hydraulic line and the slave cylinder. I have been unable to bleed the system and am not sure i want to replace the line with another quick disconnect coupling. does anyone know what the specs are on the coupling? and is it built right into the slave cylinder? I am also thinking I would like to replace the hydraulic line with something other than plastic.
would steel braided pressure hose do it? Or possibly hard brake lines, and if so what couplings do i use between the master cylinder and at the slave cylinder. Trying to keep it cheap and simple , i need my car back online and want it to stay that way.
Please help me thanx,
Woman with ideas but not enough info.
