drummer
- August 31, 2013
- 1991 Ford Explorer
I have a 1991 Ford Explorer that will run fine until you turn the car off. If the car is at operating temperature and you let it sit for 20 minutes or so the car will not start. If you get there after about 15 minutes it will start, but you have to hold the accelerator to the floor because it acts like it is flooded out. This problem seems to manifest more when the temperature outside is 75 degrees or hotter. It still does it in the winter (I live in Michigan), but you can get it started at any time by putting the accelerator to the floor. I can get it started when its hot by pouring some cool water over the valve covers, but it is still rather annoying. I have done a full tune up and appear to be getting spark, I have replaced the fuel pump in the last year, the fuel relay, the crankshaft position sensor, the throttle position sensor, I cleaned the MAF and the IAC Valve, I replaced the ICM, I have checked all of the vacuum hoses, and know I am stuck. I don't know what to replace next. The car doesn't throw any codes even when it is running rough it gives an all system pass. Please help
