1992 Explorer stalls after put into gear | Ford Explorer Forums
ccellarius32
SLC, Utah
1992 Ford Explorer
I have a 1992 explorer. When I put it into drive or reverse, it stalls on me. It only does this when I first put into drive or reverse, just after I start it. Engine idles ok and will not stall if I give a little gas as I shift. Also if I shift it into neutral then into drive or reverse, it is fine. After I get it not to stall, it runs perfect around town and on the freeway. This problem only occurs after I start it, not when I put it back into park and then into gear, only at first start up. Does anyone know what would cause this? I have ready other threads, but have not seen where anyone wrote that they only have the problem at first start up, or the nuetral shifting ok.
Forgot to mention this is a automatic transmission.
