PTurner45
- August 5, 2008
- Columbia, SC
1992 ford explorer with V-6. Odd problem, a friend said the vehicle ran ok and he had to change a starter, vehicle sat for awhile and now when he attempts to crank the engine up it will not start and this is the odd part, if you continue to crank the engine over in an attempt to start it, fuel pours from the intake plenium at the PCV tube?? I also pulled a few plugs and they were def alittle to wet to fire. Is this as he is being told (possibly) a "hung" injector issue or does it sound more like a pressure regulator problem? Fuel will pour from the intake PCV inlet once you continue to try to crank the motor. Spark plugs do have fire to each.
