kckershovel
- December 28, 2013
- Indiana
- 1991 ford f150
Let me start by saying I have done as much research before writing this as I could. I'm getting a 1994 Explorer with a bad engine and 164k on the clock so who knows on the transmission. Probably not good or not for long.
Let's start with the trans. What non electronic trans options are there to work with my stock transfer case? For this question I'm not concerned with bell housing and what engine it will fit only if it will work with my stock transfer case? C4,Aod,C5?
Next is it realistic to convert a 4x4 to 2wd during a swap like this? I'm looking for low budget and reliable I don't need 4wd however if it is just as easy to keep it I would like to.
Now for those who would say the low budget route is to just put in another 4.0 and see how the trans is. I'm not real interested in that at all. With all of the known issues with both the stock engine and trans I want something different.
Ok one idea that would use the stock trans involves swapping a C5 bell housing with sbf pattern. Using either a 250 inline six or a 302. With that, does the Stock trans have electronic OD and 3-4 shift? It is a 94 and I read in 93.5 this happened. If so will those functions still work with a carb motor swap?
Next we stick with the same engines 302,inline 200 or 250, and let's throw in the 2.3 4cyl for fun. I'm not looking for power. I want reliable, easy, mpg. I know pick two right. List your Motor/trans combo for 2wd or 4wd and why.
This is a clean rust free nice interior first gen that I'm getting for scrap price so I can justify building it the way I want it. That is an automatic carbed not 4.0 A4LD Explorer. Wife will be driving it most of the time and has knee issue so no manual swap :-(.
Ok so let her rip. I'm pretty firm on not using the pushrod 4.0. I am fairly firm on using a carburetor and a non electronically controlled Auto trans. I would love an OD. I guess there is a chance on keeping the A4LD with one of the lower power motor options like the inline 6, 2.3 4cyl or low power 302. I don't care if I retain the 4wd. I just don't want to spend allot of time and cash on making it a 2wd. So I think that is it.
Sorry in advance for the long post. Thank you for taking the time to read it. I hope it reads clearly.
