kbalser
- March 3, 2011
- MN
- 94 Eddie Bauer
My 94 Eddie Bauer has about 150K. This truck was given to my wife by her uncle, who bought it new. It was used as a daily driver. As far as I can tell, the 4WD has hardly ever been used. The truck looks and runs great.
When we put tires on the front about a month ago, the mechanic said the wheel bearings should be adjusted. I did that, using a chiltons manual for directions. I believe I had everything lined up correctly when I tightened the lug nuts. Since then, a couple of times it sounds like the left front wheel wants to engage on its own. You hear a ticking noise, pull over and stop, back up and the noise goes away. I looked through the forums here, pulled the hub and found a lot of sticky grease. I now have the hub soaking in cleaning solvent. Maybe cleaning is all it needs. Could either myself or the guy who put the tires on have damaged something in the hub by tightening it up without everything in line? There are no clips on the studs so the hub usually comes off when you pull the wheel. I would like to take the hub apart to see if there is any damage or wear. But after removing the snap ring, I can only move the cam assembly out about a half an inch. Is it possible to take these things apart at home? I have searched through the forums here and found out a lot. But I haven't seen any directions for disassembling these hubs.
By the way, since my wife drives this car part of the time, we would like to keep the auto hubs.
