1995 2nd/3rd shift problems redux
Big O Holder
Winston-Salem, NC
1995 Eddie Bauer
Hello to everyone! I've been lurking for a while but this has me baffled as for what to do next. I have a 1995 Eddie Bauer with what I assume is the original 4R55E transmission and 164K miles. When I put it in Drive or Reverse there is a moment of hesitation before engagement that doesn't bother me but another issue that does - When it shifts from 2nd to 3rd it jumps 300 to 500 revs before changing. I've heard there was a solenoid issue but everything I have seen puts it past my model year. Where should I begin to look?
A How to: Replace Fuel pressure regulator 1995- 2001 Ford Explorer 2nd Gen Stock 1995 - 2001 Explorers 6
M Replacing cat. converter on 1995 Ford Explorer 146,000 miles , second owner Stock 1995 - 2001 Explorers 0
T 1995 to 2000 / 2000 to 1995 engine / transmission swap Stock 1995 - 2001 Explorers 6
P 1995 starting issue Stock 1995 - 2001 Explorers 1
E 1995 EB: What next? Stock 1995 - 2001 Explorers 24
B 1995/96 Ford Explorer XL, V6, with spongy brake pedal after new parts Stock 1995 - 2001 Explorers 12
M 1995 Gen 2 wiper linkage Stock 1995 - 2001 Explorers 1
G 1995 Ford Explorer 4.0 Intake coolant tube question Stock 1995 - 2001 Explorers 5
A 1995 Explorer, Blown headgasket $200 is it worth it? Stock 1995 - 2001 Explorers 13
G 1995 Ford Explorer xlt 4.0L no crank, no communication Stock 1995 - 2001 Explorers 3
D 1995 Ford Explorer AirBag light Stock 1995 - 2001 Explorers 1
A 1995 Ranger will not shift while running Stock 1995 - 2001 Explorers 5
D Removing hood from 1995 XLT Tips please Stock 1995 - 2001 Explorers 4
D Stock 1995 Explorer Driver Window and other questions Stock 1995 - 2001 Explorers 11
D help with correct type of radiator for 1995 OHV Stock 1995 - 2001 Explorers 3
D 1995 XLT 4wd issues. started with light now it runs really rough Stock 1995 - 2001 Explorers 2
M Better? 1995 Explorer or 1999 Exp Xlt? Stock 1995 - 2001 Explorers 86
K 1995 ford explorer heater blows cold Stock 1995 - 2001 Explorers 4
D 1995 Eddie Bauer - Cranks but won't start when hot Stock 1995 - 2001 Explorers 23
T 1995 Explorer 4.0L OHV: "Engine Out" Timing Synchronizer/ CMP Sensor backprobe test Stock 1995 - 2001 Explorers 6
D 1995 ranger 55e trans question Stock 1995 - 2001 Explorers 3
D 1995 Ford Explorer Radio Replacement Stock 1995 - 2001 Explorers 3
H 1995 Explorer Stock 4-door XLT Max Wheel/Tire Size Stock 1995 - 2001 Explorers 1
S 1995 Explorer in 4-High for 10 miles on pavement! Stock 1995 - 2001 Explorers 29
F Hi, I'm Frank ...I'm from Antwerp (Belgium). I just bought myself a Ford Explorer(1995-1997). Stock 1995 - 2001 Explorers 6
N 1995 Explorer Stock 1995 - 2001 Explorers 1
N 1995 Manual transmission issue Stock 1995 - 2001 Explorers 9
C 1995 Ford Exp loud grinding noise while driving Stock 1995 - 2001 Explorers 7
P 1995 ford explore fule tank Stock 1995 - 2001 Explorers 2
D Best and cheapest radio for 1995 Explorer XLT Stock 1995 - 2001 Explorers 12
J 1995 Ford Explorer stuck in first gear. Stock 1995 - 2001 Explorers 1
P 1991-1994 Carpet fit 1995-2001? Stock 1995 - 2001 Explorers 0
C Using Key Fobs on a 1995 Explorer XLT Stock 1995 - 2001 Explorers 1
Indispensable Explorer 1995 Check Engine Light & intermittent low idle Stock 1995 - 2001 Explorers 2
D Question about OBD1 1-2 flash code. 1995 Explorer. Stock 1995 - 2001 Explorers 2
N 1995 explorer 4x4 transmission problems Stock 1995 - 2001 Explorers 0
E 1995 - 1997 Eddie Bauer Explorer head lights out or no high beam or low beam Stock 1995 - 2001 Explorers 0
S Thinking about buying a 1995 Explorer Stock 1995 - 2001 Explorers 4
davidk Recommend 1995 Explorer? Stock 1995 - 2001 Explorers 10
A Need help with understanding 1995 Explorer XLT EEC OBD1 Code(with video) Stock 1995 - 2001 Explorers 5
F Does a 1995 Explorer ECU have to be programmed? Stock 1995 - 2001 Explorers 3
M 1995 explorer transfer case would not come out of 4 wheel low. Now afraid to engage again, any sugg Stock 1995 - 2001 Explorers 0
B Can I install a 1995 4.0 OHV Engine into a 1997 Explorer Sport? Stock 1995 - 2001 Explorers 0
R 1995 Explorer - driving without front axles Stock 1995 - 2001 Explorers 6
E 1995. Replacing power steering cooler help. Stock 1995 - 2001 Explorers 2
L Is the fuel pump failing on my 1995 Explorer XLT? Stock 1995 - 2001 Explorers 2
L 1995 Explorer intermittant start - starter spins doesn't engage Stock 1995 - 2001 Explorers 1
R 1995 Explorer EEC-1V or EEC-V Stock 1995 - 2001 Explorers 4
E 1995 Explorer Transmission Replacement Stock 1995 - 2001 Explorers 0
L code reader for 1995 Explorer Stock 1995 - 2001 Explorers 5
Similar threads
