4R55E shift issue | Ford Explorer Forums - Serious Explorations
4R55E shift issue
brailing
1996 ford explorer
Hey guys, I need help trouble shooting a 4R55E. I bought a 95 explorer that when put in park doesn't want to shift out of first. when put manually into second it will shift, then in drive it will shift normally through all gears. If stopped and put back in park I have to repeat process. I have changed the valve body gaskets and installed a new EPC shift solenoid, but did not help. could it be a computer issue?
Any help would be appreciated. Thanks
Yes it easily comes out of park. If i take it out of park and go directly to 1st then to drive it shifts through all gears. If I go directly to drive without going to 1st first it dose not want to shift out of 1st ?
Thanks gatzdon, I will check these bolts, and the rest of the linkage.
You may also want to check the speed sensor.
