tmikey
- June 3, 2015
- NC
- 1995 Ford Aerostar AWD
Hi folks, newbie here. My 4wd light started blinking today - twice then a pause. Owner's manual said to have it serviced soon. Had to get to a doctor's appt. and it seemed to be driving ok, so off I went. Drove fine until I arrived at the doctor's office, at which point the front wheels felt like they were going to lock up at every turn through the parking lot. Finally got it backed into a parking space (presuming that I was going to have to have it towed when I came out) and pulled up your site on the handy android phone to try and see what might be going on. Thank God (and you guys!!!) I found a thread where someone described exactly the same problem, and said that he had been able to at least make the van drivable by unplugging the control module under the driver's seat, and that this is an ok temporary fix for this issue. I did that and drove it around the lot a few times and then home without issue. Got home and cleaned the contacts on the transfer case sensor connections and at the control module, didn't help. Now I need to find a source for the sensors, and am I right that this year has a sensor at the rear axle also? Didn't clean that one, yet. Also I'm curious as to the status of the system while the control module is unplugged. Are all four wheels getting equal power at this point, just the rear two, 70/30 split or what exactly? Thanks so much for any help with this, this is my 7th Aerostar (yes, you read that right) and I've put over 225K on all of them, but this is my first AWD version and I'm in new territory here. Thanks again!
