1995 Explorer XLT coolant Leak | Ford Explorer - Ford Ranger Forums - Serious Explorations
mash3d
1995 XLT
Hi, I seem to have sprung a coolant leak.
It's located just behind, below and to the right of the thermostat as you are facing it.
Take a look at the attached photo.
(dead links)
It only appears when the engine is running and comes out as a steady stream so it seems to be under pressure.
Can any one tell me where it might be coming from?
Thanks,
mike
racer_x_one
PA
'94 XLT
It's hard to tell from the picture, not wide/clear enough, but it might be the lower intake. What engine do you have?
mash3d
1995 XLT
Thanks for the replys.
The engine is a 4.0 v6
It's not a SOHC engine so will the instructions in that link still roughly work?
Thanks,
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Housing itself should be similar, getting to it may be different. GL
