kingrancher01
1995 ford explorer
Hey, I got a 1995 Ford Explorer Eddie Bauer edition. when I turn the heat on
high, it only blows cold air. I replaced the blend door actuator, and the tubes to
the heater core are hot all the way to the firewall. the heater control valve
bypass seems to be working and the engine is full of coolant. The codes read 024 and 025. Those are codes for the blend door actuator, but I just replaced it. Any ideas what
the issue could be. The fuses for all the air conditioner associated components
have been replaced. thanks
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
kingrancher01
1995 ford explorer
I replaced the actuator and it is still not working. it is the electric actuator. It is Turning until the heat gets to 68 degrees then it stops moving. what can I do to fix that
BrooklynBay
Staff member
Moderator
Brooklyn, NY
GLOCKer
Location
ATL Area
Marietta, GA
1998 Explorer Limited
I'm curious; what HVAC control head is in your truck? Is it the automatic one where you dial in the temperature like the one in my Limited?
