The #1 Ford Explorer enthusiast resource for over 25 years!
Performance Upgrades - Maintenance - Modifications - Problem Solving. Covering the Explorer, ST, Lincoln Aviator, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Aerostar.
Have a 1996 and 5.0 explorer and only clicks when trying to start it with the key. Replaced the starter solenoid and neutral saftey switch. Can't figure out. Please help!!
Welcome Fred. First thing to check would be your battery connections, make sure they are clean & tight, then check to make sure the wire at the starter is not loose. You could also try if the above doesn't work, have a helper try to start the truck while you hit the body of the starter with a hammer several times.
