1996 Ford explorer 4x4 cranks but won't start | Ford Explorer Forums
Lori greene
Fresno, ca
Fuel pump, relay, fuel cutoff switch spark, ??? How to know which it is before spend ton money
You can swap the relays around in the underhood fuse box to rule out the relay.
You can pull the carpet back and check the cut off switch isn’t triggered. You can test it with a multi meter, or jumper it out.
You can stick another plug(or high energy plug tester) in one of the plug wires and turn over to test for spark.
You can test for fuel pressure at the fuel rail, or at least have someone listen while you bump the key to listen for the pump running.
If you do not hear the fuel pump prime when you first turn the key
Next step is to apply 12 to the fuel pump directly. On Rangers and Explorers you can reach the wiring to the fuel pump rather easily. unplug the harness and you can now tap into the power and ground wires for the pump. I use a jumper box (Car battery) and I have a few male plugs here that plug into the truck, I then power the fuel pump directly and see if it runs.
The pink/black is the + and the thick black/white is the -
You can tap into the wires however you see fit, taking the 8 pin round plug apart is one option
This has saved many tanks from being dropped when I find the fuel pump is actually working fine, then I move onto the truck side of things.
Otherwise if the pump does not run, I know I need to drop the tank
