carnifex
- December 26, 2008
- Dayton, OH
- 1996 Explorer XLT
I had made a post about this previously, and the weather turned really cold and wet for a long time...and never had a chance to address it during the holidays and such.
So link to the previous post was made under Stock 1995-2001 Explorers on 11-24-2011:
http://www.explorerforum.com/forums/showthread.php?t=336846
You can read that or not, I am going to give info in this post related to what it has done today and yesterday.
Yesterday, started and ran for awhile, tried to shift into gear and motor died immediately. Went ahead with brake line replacement on rear wheels. After finishing brakes, bled the lines and got the pedal back to normal while car was not running.
Started car again, it started, but the idle seemed too high for what I was used to by noise and looked at the RPM gauge on the dash. It was running closer to 2000 RPMs than 1500 (it's usually around 1500-1600 at a guess).
I revved it up a couple times, and idle dropped down closer to normal but was still running a little fast. When pressing the brake pedal there would be a noticeable change in the RPMs on the gauge and the engine noise would change to a slight pull sound. I felt this was abnormal as I don't recall it ever doing this while sitting in parked.
Shifted it into gear and it died immediately again. To start it again I had to hold the gas pedal to the floor and it would idle a little fast like before. Settle down after revving it at least once, but still run a touch faster than normal. Brake pedal still caused pull.
At this point it was getting pretty late in the day, so stopped by auto parts store to get some ideas on frequent replacements and to get an idea on what to look for on here and the web in general. This yielded two possibilities of the IAC and MAF.....and suggestions that the torque converter in the transmission is not functioning properly.
Today, first thing I did was pull the IAC to check how crudded it up it was. The part was obviously sooted up, and I decided to just replace it. I replaced it with a part from Autozone that was missing the black cap on it, but otherwise had the same shape and orientation of the old one. The primary difference being the old one had the black cap and had NO gasket but rubber rings, where as new had no black cap and called for a gasket.
After replacing the IAC, the truck started up as normal, idle seemed fine more inline with what I remembered. The truck shifted into gear, drove it around a little bit to make sure the brakes seemed right and took it on the road. Got it up to maybe 35 and I could tell it was not shifting properly, I attributed this to the motor needing to learn from being screwed up for the last 2 months and not running properly. It would down shift with too much force and it would sometimes shift a little hard going into third. It felt like the vehicle would if I were doing extremely fast stops or accelerations versus what I was doing (casual stop and go around the block), just way too much kick on the up shift at third gear and way too much coming back down for stops. I didn't think it was a symptom of anything at the time, but throwing it in there just case.
Got it back to the work area, turned it off, popped hood looked inside for any obvious problems and tried to start it again. And it started doing the same thing as above, crank endlessly until you held the gas pedal to the floor. Idle seemed better, more normal but it still wasn't right...just a touch too fast. Wouldn't shift into gear without dieing.
Now I will note that my vehicle has had a hesitation at times when giving it gas and it did it a lot throughout this, but it didn't do it even once when I put that replacement IAC on during the first run and drive. And then it started doing it again.
So I tried cleaning the MAF, the MAF looked pretty clean, but cleaned it via directions on this website.....the motor stunk pretty bad after the cleaning for a bit but it made no obvious change in the performance of the vehicle. In fact it might have made the vehicle run a little more poorly after holding the pedal to the floor to start it, it would stutter and shudder for a bit until going into it's a little too fast idle.
At this point I tried cleaning the old IAC and putting it on, the idle went back to obviously too fast..even more pronounced before. Hovering at 2000 RPM instead of just under it like the day before (both are too fast based on past experience).
So right now I think the IAC makes a difference when changed, but I think the part I got might not have been 100% suitable despite matching on the parts store look up. I will be looking into an OEM from dealers to see if there's a possibility there for a better match up.
But I still have an obvious problem with the vehicle not wanting to start without the pedal to the floor.......after it's started once during the day. It seems like flooding, but could be heat related or even moisture related (heat of motor making something take on moisture).
I think that's covered everything I've noticed. I don't think it's the transmission simply because the motor won't start without the gas pedal down, it says something is wrong on the motor side to begin with at least.
Now a couple things to note for the history of this vehicle that I think pertain to this. It has been using more fuel than normal for awhile, I've been putting off trying to fix it until I could narrow it down. I don't drive enough for it to really hurt me on fuel costs, and I have been unemployed for sometime so I didn't want to get into part replacement without having more of an idea of the issue. And it has shown a persistent error on a oxygen sensor that has caused the check engine light to come on multiple times, I think this sensor has actually changed between resetting the codes but I can't say for sure.
So I think I need an IAC, but unless it's a miracle cure I think I have at least one other problem part. Unless the MAF is just outright dead and can do this as a result, it's clean enough that it shouldn't have caused any issues related to it being dirty before or after the cleaning I gave it.
Any ideas are welcome.... Please.
Thanks.
Thanks.
