- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
You need to check fuel pressure especially when it dies
Hearing the pump run and seeing pressure in the rail is one step, actually checking the pressure is next needs to be 36-42 psi
The mas air sensor maybe filthy from your new air intake. The breather hose needs to be installed for the crankcase breather
Intake gasket o rings will not cause the issue you are having
I suspect fuel flow issue or battery cables right off the batt
You said the fuel filter condition is in known
Maybe time for a new pump, strainer and filter
