john sullivan
- March 26, 2010
- pueblo Co
- 97 ford aerostar
When trying to replace the front parking brake (handle) cable, I cant find enough slack to reattach at the mid bracket underneath. I have both rear drums off and confirmed that the left and right cable springs are completely compressed after I used a ratched style tie down to pull the mid bracket forwaed the maximum amount. I have also taken the spring tension on the unlocked/relaxed brake handle cable wheel rotated completely forward until it stops, and locked in place with vise grips. At this position the slack spring end looks to be about straight up and the cable ball end seems to look about straight forward, as well as the lower hole for an alignment pin matching up. There are no kinks anywhere in the cables and the cable housing ends are snapped into the holes in the body fully. Im using an after market cable, but confirm the length was the same as factory. I can usually figure stuff out but not this time. What am I overlokking? Any help. Thanks
